9 years agoHow to target memory mapped by pcie testbench?
hi guys!!:)
I'm try simulate a PCIe communication and I'm setup a testbench. I just use BAR0 whose size is 4MBytes - 22bit. The address of that memories slaves are: Memorie 1 : 0x0000_0000 - 0x001f_ffff Memorie 2 : 0x0020_0000 - 0x0020_3fff Memorie 3 : 0x0020_4000 - 0x0020_41ff memorie 4 : 0x0020_4200 - 0x0020_420f Well I need to target the fourth memory, but I've cant to get good results. In the testbench there's a task which target a memory. The next is the code: target_mem_test( bar_table, // bar size/address info for endpoint tgt_bar, // bar to access target memory with 32'h0000, // starting offset from bar 512 // length of memory to test 512 );
my questions are next::confused: How I can to target to the fourth memory mapped?? That code can let me to target to fourth memory mapped? Well, I've setup two parameters and code was like: target_mem_test( bar_table, // BAR Size/Address info for Endpoint tgt_bar, // BAR to access target memory with 24'h204200, // starting offset from bar 16 // length of memory to test 512 ); I've changed that parameters because the 4th memory begin in 0x0020_42 and the length of that memory is 16.(but it doesn't work):cry:
