14 years agoHow to synthesis parallel circuit?
The codes here: always @(posedge clk or negedge rst)begin if(!rst)begin ..... end else begin if(a) .... if(b) .... if(c) .... end en...
14 years ago --- Quote Start --- Looking at your code, the rst and clk signal tests have a priority relation due to the else. This implements asynchronously resetable flip-flops. Unless the if(b) is not in an else path of if(a), there should be no priority of the if's, but there may be priority with your assigned signals - for example, if you set signal x = 1 in the if(a) part and x = 2 in the if(b) part and both a and b are true, x will be 2 after the rising clk edge even though it has been set to 1 in the if(a) part... which has been overridden by the if(b) part in such a case. Hope that helps... --- Quote End --- Thank u so much!
