14 years agoHow to synthesis parallel circuit?
The codes here: always @(posedge clk or negedge rst)begin if(!rst)begin ..... end else begin if(a) .... if(b) .... if(c) .... end en...
14 years agoLooking at your code, the rst and clk signal tests have a priority relation due to the else. This implements asynchronously resetable flip-flops.
Unless the if(b) is not in an else path of if(a), there should be no priority of the if's, but there may be priority with your assigned signals - for example, if you set signal x = 1 in the if(a) part and x = 2 in the if(b) part and both a and b are true, x will be 2 after the rising clk edge even though it has been set to 1 in the if(a) part... which has been overridden by the if(b) part in such a case. Hope that helps...
