15 years agoHow to switch on "weak pullups" for Cyclone in Quartus 10SP1
I am doing a development using a Cylclone EP1C3T100. I am using Quartus 10 SP 1 My design needs a few DIP switches, and so I thought that I can use the internal pull-ups to get the high level. But I cannot configure them in Quartus. 1. Try: I use the Ressource Property Editor, I then select "Weak Pull Up" and set it to "ON". I then run "Edit"->"Check Ressource Properties" and it becomes accepted and printed bold. But when I then look into the synthesis result files, "Weak Pull Up" for the pin is OFF and also it is off if looking into the ressource properties afterwards. 2. Try: I generally switch weak pullups using "Assignments"->"Settings"->"Fitter Settings"->"More Settings..." and there at the very bottom is also a "Weak Pull Up" selection. If I turn on this, I get a fitter error: Error: Can't place I/O pin osc_clk at pin location 10 -- I/O pin uses weak pullup, which is not supported by this pin location For methode# 2 I did not find how to turn off the weak pull up on Pin 10, all selections in the property editor are greyed out. Any idea how to solve this? I would like to save the external pull up resistor. Thanks a lot in advance, Günter (dl4mea)6 Replies
--- Quote Start --- It's done by the "Customize Columns" function in the context menu. --- Quote End --- Hello FvM, thanks a lot for your comment, now I got it. As I said, Quartus is a labyrinth of configuration options. Thanks again, Günter - Altera_Forum
--- Quote Start --- can be enabled in the pin planner. --- Quote End --- Hello, thanks for the answer. Even if it sounds foolish, can you please tell me the details steps how to enable a weak pullup in a EP1C3 device in pin planner? I had a look at all the options, but did not find the one that gives me this option. Some of the configurations in Quartus are really behind a labyrinth. Thanks, Günter - Altera_Forum
I didn't clearly understand from your post, if the reported problems have been with other pins than CLK0 (pin 10). With other pins, weak pull-up should work of course. But the resource property editor isn't the right way to do it, it's only intended for changes to a compiled design. You have to use either the assignment editor or the convenient pin planner. Columns showing the respective properties can be enabled in the pin planner.
thanks for the confirmation. But how can I reach my goal of having the weak pullups active on the switch inputs? Cheers, Günter - Altera_Forum
--- Quote Start --- Can't place I/O pin osc_clk at pin location 10 -- I/O pin uses weak pullup, which is not supported by this pin location --- Quote End --- Yes it's true. Pin10 is a dedicated clock input. Weak pull-up isn't supported for clock pins, only for general I/O pins.
