15 years agoHow to switch on "weak pullups" for Cyclone in Quartus 10SP1
Hello, I am doing a development using a Cylclone EP1C3T100. I am using Quartus 10 SP 1 My design needs a few DIP switches, and so I thought that I can use the internal pull-ups to get th...
15 years agoI didn't clearly understand from your post, if the reported problems have been with other pins than CLK0 (pin 10). With other pins, weak pull-up should work of course. But the resource property editor isn't the right way to do it, it's only intended for changes to a compiled design. You have to use either the assignment editor or the convenient pin planner. Columns showing the respective properties can be enabled in the pin planner.
