12 years agoHow to solve this " The design unit was not found" in Modelsim
Hi, All.
Please look at my problem and give a tip.. T.T Environment: Altera11.1, Modelsim 10.0c, MAX7000S Work: 1. Designing a schematic: I used Block or symbols stored into "other-maxplus2-4count" of the altera11.1 library 2. And then compiling and creating this ~.bdf into ~.v file 3. In order to simulate ~.v file, run Modelsim. But this problem happened Loading some flip-flop and divider components is okay. But this is cannot be solved. Please help me Example Error code ------------------------------------------------------------------------------------------------------------------------ vsim work.testbench_test# vsim work.testbench_test # Loading work.testbench_test# Loading work.test# ** Error: (vsim-3033) C:/altera/11.1/temp/test.v(54): Instantiation of 'count4' failed. The design unit was not found.# Region: /testbench_test/U1_test# Searched libraries:# C:\altera\11.1\temp\work# Error loading design ------------------------------------------------------------------------------------------------------------------------- Thanks in advance, all1 Reply
have you got the altera libraries included in modelsim. Im not sure if the maxplus2 libraries are included by default, or if they even exist (they are very old libraries). I suggest using the lpm and altera_mf libraries as these do have modelsim compatible libraries.
