  • ONO20221130's avatar
    ONO20221130
    Thank you for your reply.
    I could simulate normally by using these files. I appreciate it.
  • Ash_R_Altera's avatar
    Ash_R_Altera
    Thanks for the information. I will get the required information from internal team and get back to you.
    Thank you for your patience.
    Ash_R_Altera
    The error message is missing in your previous reply. Can you please put it once again?
    Also, please indicate which simulator you are using and how are you trying to use the model?
      ONO20221130
      Please refer to this.
      simulator : PrimeSim HSPICE -- S-2021.09 linux64
      netlist:
      .include "./MAX10ADC_SPICEModel/nonprescalar_rc.cir_en"
      .ac dec 10 1 10
      .end
      error:
      **error** No connections on ground node.
      **warning** associated with encrypted blocks weresuppressed due to encrypted content
      Warning:'No DC path nodes' occurs 9 times
      No DC path from the following nodes,connected with gdcpath:
      Warning:'1 connection nodes' occurs 1 times
      Summary of 1 connection from the following nodes:
      Warning:'No Tran path ' occurs 9 times
      Summary of No Tran path from the following nodes:
      ****** Statistics of Ignored Elements ******
      Inductors : 2
      ****** Circuit Statistics ******
      # nodes = 11 # elements = 11
      # resistors = 5 # capacitors = 6 # inductors = 0
      # mutual_inds = 0 # vccs = 0 # vcvs = 0
      # cccs = 0 # ccvs = 0 # volt_srcs = 0
      # curr_srcs = 0 # diodes = 0 # bjts = 0
      # jfets = 0 # mosfets = 0 # U elements = 0
      # T elements = 0 # W elements = 0 # B elements = 0
      # S elements = 0 # P elements = 0 # va device = 0
      # vector_srcs = 0 # N elements = 0
    Ash_R_Altera
    I am not sure of what is the ask here. Can you clarify more please?
    The zip file on the website consists of SPICE model of ADC input. There is a Readme file in the zip file. Can you please go through that?
      ONO20221130
      Thank you for your replay.
      I read the Readme.
      At first, I thought that only including the model file in test bench was OK. But there is an error from simulator like this.
      So I think the test bench needs an instance from the model and some voltage sources.
      But I am not sure of how to script test bench because the Readme does not explain the model name and port names .
      (I don't know the model name and port names from the model file that is encrypted.)
