11 years agoHow to simulate the FPGA neural network in Altera
I want to simulate the some kind of schematics that work by principle of neural networks. I have Altera Quadrus 11. But when trying create some verilog or vhdl code I see that compilation and simul...
11 years agoYou should be able to apply Fixed point toolbox to the whole design. I would be careful of multiplication operations since you can reach overflow or saturation easily if you dont have enough bit width. Once you generate your HDL you can import it into Modelsim. You should also write a quick verilog testbench to simulate some inputs. Technically you should see the same waveforms in modelsim as you see in simulink if you use the same inputs.
