11 years agoHow to simulate the FPGA neural network in Altera
I want to simulate the some kind of schematics that work by principle of neural networks. I have Altera Quadrus 11. But when trying create some verilog or vhdl code I see that compilation and simul...
11 years agoOk you definitely need to upgrade matlab. Also in the simulation configuration panel, you are probably still using "Variable Step". You can change that to "Fixed Step" then use 0.001.
Sample Time is in "seconds". So Sample time of 1 = 1 second per step. Sample Time of 0.001 is 1/1000 of second per step. Sample Time of -1 mean use the same sample time as the block before or as set in the configurations. Yeah your simulimk/matlab is so old that I can't even back convert it that far.
