11 years agoHow to simulate the FPGA neural network in Altera
I want to simulate the some kind of schematics that work by principle of neural networks. I have Altera Quadrus 11. But when trying create some verilog or vhdl code I see that compilation and simul...
11 years agoThe dsp blockset works like any other blockset in Simulink. Place Altera's blocks to create your system. Then simulate your result. You will need a license to generate HDL files from your design. Since you are doing this through the school, you should be able to get a student license or a 60 - day temporary license with the help of your professor. You can place a request with Altera to send you a license for DSP builder.
So make your circuit in Simulink using the dsp blockset from Altera. If you've never used simulink before, you should do a quick search, but basically it is a graphical flow program. You place blocks and connect them to indicate data flow/operation. Not sure how Xilinx and Labview interface, but it is probably the same deal.
