8 years agohow to simulate NIOS II generated in Qsys_Pro v17.0
Hi, I'm using Quartu_Prim_Pro v17.0, I use QsysPro to generate a NIOS II system and testbench, when I try to run simulation using cadence NCSIM, I found the NIOS cpu model is encrypted and not ...
8 years agoHi Terry,
For NIOS simulation there are two parts. Software (C code for NIOS porcessor) / Hardware (NIOS Qsys system ) To simulate it completely software + hardware part it is only supported with Modelsim. You may refer to application note on detailed steps. https://www.altera.com/en_us/pdfs/literature/an/an351.pdf Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
