8 years agohow to simulate NIOS II generated in Qsys_Pro v17.0
Hi, I'm using Quartu_Prim_Pro v17.0, I use QsysPro to generate a NIOS II system and testbench, when I try to run simulation using cadence NCSIM, I found the NIOS cpu model is encrypted and not ...
8 years agoYou could take a look at the following resources to help you with your simulation:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an351.pdf https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-simulating-niosii.html
