8 years agohow to simulate NIOS II generated in Qsys_Pro v17.0
Hi, I'm using Quartu_Prim_Pro v17.0, I use QsysPro to generate a NIOS II system and testbench, when I try to run simulation using cadence NCSIM, I found the NIOS cpu model is encrypted and not ...
8 years ago --- Quote Start --- Hi, If you've enabled the "Generate simulation models" option in Qsys while generating the system, the tool will generate all simulation models for the blocks used in the Qsys design. Simulations libraries are generated for ModelSim, QuestaSim, Cadence and Synopys . This option will be present in the window that pops-up when you press the "Generate" or "Finish" buttons. --- Quote End --- the .vo file is one of the output file when I press the "Generate", the problem is it is encrypted and not recognized by ncsim.
