8 years agohow to simulate NIOS II generated in Qsys_Pro v17.0
Hi, I'm using Quartu_Prim_Pro v17.0, I use QsysPro to generate a NIOS II system and testbench, when I try to run simulation using cadence NCSIM, I found the NIOS cpu model is encrypted and not ...
8 years agoHi Anand,
There is no error during compile and elaboration, but the NIOS cpu RTL used in simulation is encrypted and not recognized by NCSIM, NCSIM does not report error, but in simulation nothing toggles in NIOS CPU. Please find attached .vo file generated by Qsys_Pro. Thanks for your support.
