8 years agohow to simulate NIOS II generated in Qsys_Pro v17.0
Hi, I'm using Quartu_Prim_Pro v17.0, I use QsysPro to generate a NIOS II system and testbench, when I try to run simulation using cadence NCSIM, I found the NIOS cpu model is encrypted and not ...
8 years agoThanks for you reply.
I'm using Quartus Prime Pro V17.0, Qsys_pro v17.0, cadence incisiv v13.20. I don't think tool version is causing problem, I can use Quartus v13.1 to generate NIOS core and simulate it without any problem. Now I need to migrate to Arria 10, so when I generate NISO in Qsys_Pro v17, it only gives me encrypted file <file_name>.vo, below is part of the .vo file. `pragma protect begin_protected `pragma protect version=1 `pragma protect author="Intel Corporation" `pragma protect encrypt_agent="Quartus Prime Pro Software" `pragma protect encrypt_agent_info="17.0" `pragma protect key_keyowner="Aldec" `pragma protect key_method="rsa" `pragma protect key_keyname="ALDEC15_001" `pragma protect encoding=(enctype = "base64", line_length = 76, bytes = 256) `pragma protect key_block BqdMQZuWP/tcTWnfV5UVLBLIusbnMvgyDlzxghFsC9EWkY37CLtcIU52onWzGaZ81ZJ7WjWRFNcL p4SpxJKw82uykdx4m5MoZJc/XJ5/5Wco3iR2GHG/ZPPZpiP9DyEsn404aFYn8UyDuTurd8JF57am KuSMYnSZ+l3yccoDc/O3p/aROyYtczvtSyY7H9dxO/6NRI/dijtKuTFeBSl4/J61T96cI1TejMHO HpdVblEtKZ0D6TTlLn+xcg4nLBHWctvO4EfjQ4rMBHKHPn2c2koOuKnP5Y6V4u9sQ0p4C1noaqiP 1MBxeVoWu/vDKzbXY/GUwB3XRqBmFVQ16Z9Wqg== Thanks.
