8 years agohow to simulate NIOS II generated in Qsys_Pro v17.0
Hi, I'm using Quartu_Prim_Pro v17.0, I use QsysPro to generate a NIOS II system and testbench, when I try to run simulation using cadence NCSIM, I found the NIOS cpu model is encrypted and not ...
8 years agoHi Terry, You can simulate Nioss II using Modelsim-Altera/Cadence NC-Sim. Requirements for Model sim. ■ The Quartus® II software version 11.0 or later ■ ModelSim-Altera Edition version 6.6d or higher ■ Nios II Embedded Design Suite version 11.0 or later Refer below https://www.altera.com/documentation/mwh1410385117325.html#mwh1410383407761 ModelSim:https://www.altera.com/en_us/pdfs/literature/an/an351.pdf Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
