Sijith's avatar
Sijith
2 years ago
How to simulate a design created in Platform Designer System
As I am comparatively new to Quartus Prime, I would like to know how to simulate my design that is created using Platform Designer System. I would like to elaborate a bit: my counter.v module is converted to a custom IP and I integrated that with an Avalon FIFO IP in platform designer system. Then synchronized all components and then executed "Generated HDL" and "Generate test bench" option in Platform Designer System. Also, I compiled the whole design in Quartus Prime Pro. May I know what I have to do to simulate the whole design? (I have model-sim with my Quartus Prime Pro 18.1.). I have got this doubt since I am using an off the shelf IP (Avalon FIFO IP) and a custom generated IP in my design.
  • Hi,
    The testbench counter_fifo_tb.v that I sent to you before is just an example. If you want to get proper output waveform, you have to change a bit on the stimulus.
    Below attached the edited testbench and proper output waveform image. As for the functionality, probably you still need to further verify from your side.
    Sheng
  • Sijith's avatar
    Sijith
    Hi Thank you very much!
    I have noticed that when I simulate just counter module (using counter_tb.v, that I attached in earlier message) the wave form of the data output (avalon_data) behaves as normal (have starting value 00000000000000000000000000000001) and starts the data with 32b'1 (please see attached Capture_wave_counter.PNG). But at the same time, when I simulate the counter_fifo with the testbench counter_fifo_tb.v . The fifo_0_out_readdata looks something different than the and the first entry is `00000001000000000000000000000000` (looks like counting started from the 8th bit. Please see the picture Capture_wave_counter_fifo.PNG). Also please see Counter_fifo_wave_1.PNG
    Is it something to do with the FIFO parameter setting? You can see from the Counter_FIFO/counter_fifo.qsys file the parameters I used (also see the attached counter_fifo_qsys.PNG). I am just wondering that setting channel width parameter =8 in Avalon-ST Port settings of FIFO IP has to do something with this? (as you can see in counter.v, there is no signal named "channel" defined in it). I read from the FIFO IP manual that 'channel" signal is not mandatory one, and would like to make sure that the did not make any difference here.
    I am wondering that whether is still missing?
    Thanks again!
  • Sijith's avatar
    Sijith
    Hi Sheng,
    Recently I have got a mail from Intel community that suggesting to open a new thread. If I want to raise my latest question as a fresh case, I am afraid that I may have to summarize the whole discussion here the new thread too. Is there any other way to circumvent this?
