8 years agoHow to Setup Output Using GPIO
[h=2][/h]usually i construct logical circuit then assign input switch n push button and for output using led and seven segment.... Now i want try GPIO but i dont know how to use and assign pin planne...
8 years agoUse the pin planner provided by Quartus IDE and the user manual for your board, to decide which pins are mapped to which GPIO pins.
Later update the preloader and device tree, and then you should have it working.
