8 years agoHow to Setup Output Using GPIO
[h=2][/h]usually i construct logical circuit then assign input switch n push button and for output using led and seven segment.... Now i want try GPIO but i dont know how to use and assign pin planne...
8 years agoGPIO is quite common IP. Any eval kit or board reference design with NIOS would walk you through http://www.alterawiki.com/wiki/bemicro_max_10 .
