10 years agoHow to setup a wireless communication system between two FPGA boards
Hello, I'm totally new to FPGA. I need to develop a wireless communication system between two FPGA boards with high data rate. Do you have suggestions about this topic? Thank you very mu...
10 years ago --- Quote Start --- Did you Check this? http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005725.html#a You may choose the components and transmission techniques based on your requirement. You may expect help for interfacing the component & FPGA device. When you used WIFI with micro-controller, (typically if the WIFI module has TCP/IP stack into it) the interface between WIFI module & Micro-controller would be a SPI. Are you looking for similar solution or is it something else? --- Quote End --- I could use the 802.11n protocol. Can you link some document which shows how to connect a Wi-Fi module to an FPGA? Thank you for your help!
