PHuan25
7 years agoHow to setup 4ch 25g ethernet in one bank in stratix 10 L-tile?
I had setup 2ch 25g ethernet in one bank in stratix 10 successfully. But when I want to setup 4ch, it always recognized 2ch only. I follow the spec. to config two ATX PLL ip for Main and Clock Buff...
Deshi_Intel
7 years agoHi Phuan25,
You can generate 25G 4 channels example design directly from 25G IP GUI. Refer to attachment.
From the example design, you can see 25G IP is using 2 ATX PLL to clock 4 25G channels. (one ATX PLL to clock 2 25G channels each)
dlim
