How to set watchdog value for reconfiguration of MAX10?
Thanks for your idea. While The problem is that workers in factory can’t compile. They just can program a file into FPGA.
They will edit a file with different serial number to each product and then program the file into FPGA.
Is there a method that I can edit a file and then directly program the file into FPGA without compiling. Thanks!
. The serial number will be set by workers in the factory ,then they can only program a file with serial number into FPGA. This will be done independently with the application pof. The worker in factory can't compile FPGA project and they can only do the programming with Jtag. So they just modify the file and download this file directly into UFM. So how will this be realized. Thanks very much!
- ShafiqY_Intel6 years ago
Yes, you're right. Modify the file and program directly into UFM.
I hope you can move forward with your design.
Thank you for choosing and trust our product. :)
