16 years agohow to set signalTapII?
I have a requirement like this: when signa A is in falling edge ,OR signa B is in falling edge ,OR signa C is in falling edge ,then signalTapII will capture the wave,how can i setup it?
16 years ago --- Quote Start --- I have a requirement like this: when signa A is in falling edge ,OR signa B is in falling edge ,OR signa C is in falling edge ,then signalTapII will capture the wave,how can i setup it? --- Quote End --- Hi, you can use the "Advanced" option in Signaltap. When open the "setup" tab in the signaltap file, you choose for Trigger Conditions "Basic" or "Advanced". When you choose "advanced" you get access to a kind of a schematic, where you can define your trigger conditions. I have a small project attached. Have look to it. Kind regards GPK
