17 years agoHow to set analog delay MaxPlusII
Hi, I need to set a delay following a rising_edge of a sig_a. In order to do that, I have utilized the: c<=sig_a; x <= c after# nS; -- where I can select the# through a data on the bus. ...
17 years agoI am simulating the above code, but compiler is warning for:
--- Quote Start --- Warning: Design contains 4 input pin(s) that do not drive logic Warning (15610): No output dependent on input pin "sig_go" Warning (15610): No output dependent on input pin "sel[0]" Warning (15610): No output dependent on input pin "sel[1]" Warning (15610): No output dependent on input pin "sel[2]" Warning: No paths found for timing analysis --- Quote End --- Analyzing it with Modelsim-altera... no changes on output while changing sig_go. Pls, could you help? Thanks
