17 years agoHow to set analog delay MaxPlusII
Hi, I need to set a delay following a rising_edge of a sig_a. In order to do that, I have utilized the: c<=sig_a; x <= c after# nS; -- where I can select the# through a data on the bus. ...
17 years agoThanks for ur reply,
I tried that statment yesterday while reading the manual, but simulator is not showing any delay. I believe is due to the standard simulator I am utilizing, and I think I should utilize the post fitting one (verilog?). If so I need to ur help in picking and setting that because from the manual I am still not able to make it working (error with "executable" file not found???, this simulator is not so intuitive...). CPLD I am utilizing is a EPM7128-10 and f=100Mhz. code I wrote is below... but it doesn't show any "pulse", could you help?:
library ieee;
use ieee.std_logic_1164.all;
entity analog_delay is
port(
sig_go: in std_logic;
sel: in std_logic_vector(2 downto 0);
z: out std_logic
end analog_delay;
architecture delay_ns of analog_delay is
signal a,b,c,d,e,f,g,y: std_logic;
attribute syn_keep: boolean;
attribute syn_keep of a,b,c,d,e,f,g: signal is true;
begin
sel_delay: process (sig_go,sel,a,b,c,d,e,f,g,y)
begin
-- delay input signal
a <= not(not(not( not sig_go)));
b <= not (not a);
c <= not (not b);
d <= not (not c);
e <= not (not d);
f <= not (not e);
g <= not (not f);
-- mux select delay_ns
case sel is
when "000" => y <= sig_go;
when "001" => y <= a;
when "010" => y <= b;
when "011" => y <= c;
when "100" => y <= d;
when "101" => y <= e;
when "110" => y <= f;
when "111" => y <= g;
end case;
-- results: pulse
z <= sig_go and (not y);
end process sel_delay;
end delay_ns;
Thanks a lot for ur help and contribution in making it working...
