17 years agoHow to set analog delay MaxPlusII
Hi, I need to set a delay following a rising_edge of a sig_a. In order to do that, I have utilized the: c<=sig_a; x <= c after# nS; -- where I can select the# through a data on the bus. ...
17 years agoI mentioned the basic method in my previous post, it' by synthesis attributes.
The syntax is documented in the Quartus manual, it's basicly like belowsignal my_wire: std_logic;
attribute syn_keep: boolean;
attribute syn_keep of my_wire: signal is true; You can expect to need about 4 or 5 logic cells per 1 ns delay with Cyclone III FPGA, the MAX II value should be similar. For a compact coding, you can apply the synthesis attribute to a std_logic_vector rather than individuals signals.
