17 years agoHow to set analog delay MaxPlusII
Hi, I need to set a delay following a rising_edge of a sig_a. In order to do that, I have utilized the: c<=sig_a; x <= c after# nS; -- where I can select the# through a data on the bus. ...
17 years agoThanks for the reply.
I tried with Quartus web edition, but I have the same result... VHDL compiler recognize the "after" keyword, but I see want gnerate any delay, my question is why it is anable that? Anyway, is there a way to insert a "chain" of buffer in order to obtain a delay by 1nS? I don't need to be precise, I mean +/- 1nS is OK too. I wrote below code, but simulator doesn't show any "pulse" (should I change the quartus default one?) a <= sig_in; b <= not (not a); c <= b; d <= not (not c); x <= b and not d; Thanks for your help.
