16 years agoHow to save a 256kbyte samples with Arria II GX 190
Hi all, I'm using an ArriaIIGX190 Device. I have a design that recieves 8 channels to and I need to save from each channel 256Kbyte samples, meaning 2Mbyte samples for the whole design. ...
16 years agoThere are some more details I didn't mention before:
1. The FPGA recieve the channels as DDR in 500Mbps (1Gbps data rate). 2. The ArriaIIGX190 (780 pins) has only 32 DQ/DQS or 16x3 DQ/DQS pins. Thank you, Alon Goren
