15 years agoHow to request multiply MSI interrupts?
Hi !!!
Developing a network device driver on Arria2 GX (Avalon-ST). Is it possible to set a vector of 8 MSI interrupts , if the design supports only MSI interrupts, not MSI - X? From the side of device driver developer - to request 8 separate interrupt handlers, to handle 8 packet queues. pci_enable_msi_block() returns 1.This means, that it's possible to request only 1 interrupt line. The capabilities of device: Capabilities: [78] Power Management version 3 Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-) Status: D0 PME-Enable- DSel=0 DScale=0 PME- Capabilities: [80] Express (v1) Endpoint, MSI 00 DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported- RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ MaxPayload 128 bytes, MaxReadReq 512 bytes DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend- LnkCap: Port# 1, Speed 2.5GT/s, Width x4, ASPM L0s, Latency L0 unlimited, L1 unlimited ClockPM- Suprise- LLActRep- BwNot- LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+ ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt- LnkSta: Speed 2.5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt- Developing under Linux. Best Regards, Igor39 Replies
Ok
I already know about this book. Now my concern is to create a simple design which handle MSI for test purpose first. Hopefully the Interrupt Request Line (MSI=1) would be enough for the driver to handle several I/O Devices(6 UARTs, 1 CAN, others). That is for my Internship. - Altera_Forum
Linux Device Driver Third Edition , Essential Linux Device drivers will help you
MSI = 1 means that the driver if able to request 1 interrupt line.
You have to choose MSI-X or MSI in Quartus. Also to set number of vectors. Driver than is able to request irqs, which you have specified in yours design. Are you writing driver for Linux?
Ok but with my Cyclone IV GX I have MSI= 1
1) what that means? Vector or just one Interrupt? can handled multiple Interrupts with this capabilty parameter? 2) Secondly How can I set the MSIx Interrupt Handling instead of MSI with ALTERA.(with my software or is there any configuration setting with PCI Express Compiler) - Altera_Forum
HI
pci_enable_msi (struct pci_dev * dev); pci_enable_msi_block (struct pci_dev * dev, unsigned int nvec); (On x86 arch patch is needed). If H/W is capable, use MSI-X interrupts instead MSI. Regards, Igor - Altera_Forum
Hi
please I am newbie on MSI with ALTERA: Do you have a piece of code as example implementing PCIe Driver with MSI? - Altera_Forum
Thank's for reply I've missed that piece of lspci. Capabilities: [50] Message Signalled Interrupts: Mask- 64bit+ Queue=0/5 Enable+ Address: 00000000fee0300c Data: 41a1 Now I am able to request multiply MSI's. There is a kernel patch , which allow's multiply MSI's on x86 arch. - Altera_Forum
The Capabilities' field imply that you only have one MSI enabled on your FPGA. It should read MSI 07 instead of MSI 00.
