15 years agoHow to request multiply MSI interrupts?
Hi !!! Developing a network device driver on Arria2 GX (Avalon-ST). Is it possible to set a vector of 8 MSI interrupts , if the design supports only MSI interrupts, not MSI - X? From the...
15 years agoHI
pci_enable_msi (struct pci_dev * dev); pci_enable_msi_block (struct pci_dev * dev, unsigned int nvec); (On x86 arch patch is needed). If H/W is capable, use MSI-X interrupts instead MSI. Regards, Igor
