8 years ago
How to reduce Interconnect Delay?!
I have designed a mux in Cyclone IV-E device.
I need to meet the Pin to Pin delay constraint of 10 ns.
Tools used are Quartus II 14.0 and Timequest.
I am geting data path with delay of 13.309ns...IC delay of this path is found to be ~7.5ns:(:confused:
Part of report is added below.
Slack
From Node
To Node
Launch Clock
Latch Clock
Relationship
Clock Skew
Data Delay
-3.309
unc_jtag_tdi
tdi_unc2
n/a
n/a
10
0
13.309
Is it possible to reduce this delay?
The logic implemented is a combo mux!
I have even tried a direct pin to pin mapping wihout any logic...and data delay is 7.496 for that(IC Delay is 3.640ns)!!
Neeraj G N
    I'm pretty sure you'd need to constrain the two pins to a virtual clock, otherwise I don't think Quartus is actually going to treat that as a timed path.
    Hi sstrell,
    Thanks for your time.
    Launch and latch clock is not present because its an input to output data path.
    code is added below, all signals are I/O s.
    always @(jtag_mux_sel or unc_jtag_tdi or unc_jtag_trst_l or unc_jtag_tms or unc_jtag_tck or tdo_unc0 or tdo_unc1 or tdo_unc2 or tdo_unc3)
    begin
    case(jtag_mux_sel)
    2'b00:begin
    unc_jtag_tdo = tdo_unc0;
    tdi_unc0 = unc_jtag_tdi;
    trst_l_unc0 = unc_jtag_trst_l;
    tms_unc0 = unc_jtag_tms;
    tck_unc0 = unc_jtag_tck;
    tdi_unc1 = 1'b0;
    trst_l_unc1 = 1'b0;
    tms_unc1 = 1'b0;
    tck_unc1 = 1'b0;
    tdi_unc2 = 1'b0;
    trst_l_unc2 = 1'b0;
    tms_unc2 = 1'b0;
    tck_unc2 = 1'b0;
    tdi_unc3 = 1'b0;
    trst_l_unc3 = 1'b0;
    tms_unc3 = 1'b0;
    tck_unc3 = 1'b0;
    end
    2'b01:begin
    tdi_unc0 = 1'b0;
    trst_l_unc0 = 1'b0;
    tms_unc0 = 1'b0;
    tck_unc0 = 1'b0;
    unc_jtag_tdo = tdo_unc1;
    tdi_unc1 = unc_jtag_tdi;
    trst_l_unc1 = unc_jtag_trst_l;
    tms_unc1 = unc_jtag_tms;
    tck_unc1 = unc_jtag_tck;
    tdi_unc2 = 1'b0;
    trst_l_unc2 = 1'b0;
    tms_unc2 = 1'b0;
    tck_unc2 = 1'b0;
    tdi_unc3 = 1'b0;
    trst_l_unc3 = 1'b0;
    tms_unc3 = 1'b0;
    tck_unc3 = 1'b0;
    end
    2'b10:begin
    tdi_unc0 = 1'b0;
    trst_l_unc0 = 1'b0;
    tms_unc0 = 1'b0;
    tck_unc0 = 1'b0;
    tdi_unc1 = 1'b0;
    trst_l_unc1 = 1'b0;
    tms_unc1 = 1'b0;
    tck_unc1 = 1'b0;
    unc_jtag_tdo = tdo_unc2;
    tdi_unc2 = unc_jtag_tdi;
    trst_l_unc2 = unc_jtag_trst_l;
    tms_unc2 = unc_jtag_tms;
    tck_unc2 = unc_jtag_tck;
    tdi_unc3 = 1'b0;
    trst_l_unc3 = 1'b0;
    tms_unc3 = 1'b0;
    tck_unc3 = 1'b0;
    end
    2'b11:begin
    tdi_unc0 = 1'b0;
    trst_l_unc0 = 1'b0;
    tms_unc0 = 1'b0;
    tck_unc0 = 1'b0;
    tdi_unc1 = 1'b0;
    trst_l_unc1 = 1'b0;
    tms_unc1 = 1'b0;
    tck_unc1 = 1'b0;
    tdi_unc2 = 1'b0;
    trst_l_unc2 = 1'b0;
    tms_unc2 = 1'b0;
    tck_unc2 = 1'b0;
    unc_jtag_tdo = tdo_unc3;
    tdi_unc3 = unc_jtag_tdi;
    trst_l_unc3 = unc_jtag_trst_l;
    tms_unc3 = unc_jtag_tms;
    tck_unc3 = unc_jtag_tck;
    end
    default:begin
    tdi_unc1 = 1'b0;
    trst_l_unc1 = 1'b0;
    tms_unc1 = 1'b0;
    tck_unc1 = 1'b0;
    tdi_unc2 = 1'b0;
    trst_l_unc2 = 1'b0;
    tms_unc2 = 1'b0;
    tck_unc2 = 1'b0;
    tdi_unc3 = 1'b0;
    trst_l_unc3 = 1'b0;
    tms_unc3 = 1'b0;
    tck_unc3 = 1'b0;
    end
    endcase
    end
    # ###SDC is added below####
    set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc0}] 10.000
    set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc1}] 10.000
    set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc2}] 10.000
    set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc3}] 10.000
    set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc0}] 10.000
    set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc1}] 10.000
    set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc2}] 10.000
    set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc3}] 10.000
    set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc0}] 10.000
    set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc1}] 10.000
    set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc2}] 10.000
    set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc3}] 10.000
    set_max_delay -from [get_ports {tdo_unc0}] -to [get_ports {unc_jtag_tdo}] 10.000
    set_max_delay -from [get_ports {tdo_unc1}] -to [get_ports {unc_jtag_tdo}] 10.000
    set_max_delay -from [get_ports {tdo_unc2}] -to [get_ports {unc_jtag_tdo}] 10.000
    set_max_delay -from [get_ports {tdo_unc3}] -to [get_ports {unc_jtag_tdo}] 10.000
    set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc0}] 5.000
    set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc1}] 5.000
    set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc2}] 5.000
    set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc3}] 5.000
    set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc0}] 5.000
    set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc1}] 5.000
    set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc2}] 5.000
    set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc3}] 5.000
    set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc0}] 5.000
    set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc1}] 5.000
    set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc2}] 5.000
    set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc3}] 5.000
    set_min_delay -from [get_ports {tdo_unc0}] -to [get_ports {unc_jtag_tdo}] 5.000
    set_min_delay -from [get_ports {tdo_unc1}] -to [get_ports {unc_jtag_tdo}] 5.000
    set_min_delay -from [get_ports {tdo_unc2}] -to [get_ports {unc_jtag_tdo}] 5.000
    set_min_delay -from [get_ports {tdo_unc3}] -to [get_ports {unc_jtag_tdo}] 5.000
    Neeraj
    Why do launch and latch clocks say n/a?
    Can you post code and relevant SDC?
