8 years agoHow to reduce Interconnect Delay?!
Hi, I have designed a mux in Cyclone IV-E device. I need to meet the Pin to Pin delay constraint of 10 ns. Tools used are Quartus II 14.0 and Timequest. I am geting data path with delay o...
8 years agoHi sstrell,
Thanks for your time. Launch and latch clock is not present because its an input to output data path. code is added below, all signals are I/O s. always @(jtag_mux_sel or unc_jtag_tdi or unc_jtag_trst_l or unc_jtag_tms or unc_jtag_tck or tdo_unc0 or tdo_unc1 or tdo_unc2 or tdo_unc3) begin case(jtag_mux_sel) 2'b00:begin unc_jtag_tdo = tdo_unc0; tdi_unc0 = unc_jtag_tdi; trst_l_unc0 = unc_jtag_trst_l; tms_unc0 = unc_jtag_tms; tck_unc0 = unc_jtag_tck; tdi_unc1 = 1'b0; trst_l_unc1 = 1'b0; tms_unc1 = 1'b0; tck_unc1 = 1'b0; tdi_unc2 = 1'b0; trst_l_unc2 = 1'b0; tms_unc2 = 1'b0; tck_unc2 = 1'b0; tdi_unc3 = 1'b0; trst_l_unc3 = 1'b0; tms_unc3 = 1'b0; tck_unc3 = 1'b0; end 2'b01:begin tdi_unc0 = 1'b0; trst_l_unc0 = 1'b0; tms_unc0 = 1'b0; tck_unc0 = 1'b0; unc_jtag_tdo = tdo_unc1; tdi_unc1 = unc_jtag_tdi; trst_l_unc1 = unc_jtag_trst_l; tms_unc1 = unc_jtag_tms; tck_unc1 = unc_jtag_tck; tdi_unc2 = 1'b0; trst_l_unc2 = 1'b0; tms_unc2 = 1'b0; tck_unc2 = 1'b0; tdi_unc3 = 1'b0; trst_l_unc3 = 1'b0; tms_unc3 = 1'b0; tck_unc3 = 1'b0; end 2'b10:begin tdi_unc0 = 1'b0; trst_l_unc0 = 1'b0; tms_unc0 = 1'b0; tck_unc0 = 1'b0; tdi_unc1 = 1'b0; trst_l_unc1 = 1'b0; tms_unc1 = 1'b0; tck_unc1 = 1'b0; unc_jtag_tdo = tdo_unc2; tdi_unc2 = unc_jtag_tdi; trst_l_unc2 = unc_jtag_trst_l; tms_unc2 = unc_jtag_tms; tck_unc2 = unc_jtag_tck; tdi_unc3 = 1'b0; trst_l_unc3 = 1'b0; tms_unc3 = 1'b0; tck_unc3 = 1'b0; end 2'b11:begin tdi_unc0 = 1'b0; trst_l_unc0 = 1'b0; tms_unc0 = 1'b0; tck_unc0 = 1'b0; tdi_unc1 = 1'b0; trst_l_unc1 = 1'b0; tms_unc1 = 1'b0; tck_unc1 = 1'b0; tdi_unc2 = 1'b0; trst_l_unc2 = 1'b0; tms_unc2 = 1'b0; tck_unc2 = 1'b0; unc_jtag_tdo = tdo_unc3; tdi_unc3 = unc_jtag_tdi; trst_l_unc3 = unc_jtag_trst_l; tms_unc3 = unc_jtag_tms; tck_unc3 = unc_jtag_tck; end default:begin unc_jtag_tdo = tdo_unc0; tdi_unc0 = unc_jtag_tdi; trst_l_unc0 = unc_jtag_trst_l; tms_unc0 = unc_jtag_tms; tck_unc0 = unc_jtag_tck; tdi_unc1 = 1'b0; trst_l_unc1 = 1'b0; tms_unc1 = 1'b0; tck_unc1 = 1'b0; tdi_unc2 = 1'b0; trst_l_unc2 = 1'b0; tms_unc2 = 1'b0; tck_unc2 = 1'b0; tdi_unc3 = 1'b0; trst_l_unc3 = 1'b0; tms_unc3 = 1'b0; tck_unc3 = 1'b0; end endcase end # ###SDC is added below#### set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc0}] 10.000 set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc1}] 10.000 set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc2}] 10.000 set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc3}] 10.000 set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc0}] 10.000 set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc1}] 10.000 set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc2}] 10.000 set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc3}] 10.000 set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc0}] 10.000 set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc1}] 10.000 set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc2}] 10.000 set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc3}] 10.000 set_max_delay -from [get_ports {tdo_unc0}] -to [get_ports {unc_jtag_tdo}] 10.000 set_max_delay -from [get_ports {tdo_unc1}] -to [get_ports {unc_jtag_tdo}] 10.000 set_max_delay -from [get_ports {tdo_unc2}] -to [get_ports {unc_jtag_tdo}] 10.000 set_max_delay -from [get_ports {tdo_unc3}] -to [get_ports {unc_jtag_tdo}] 10.000 set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc0}] 5.000 set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc1}] 5.000 set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc2}] 5.000 set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc3}] 5.000 set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc0}] 5.000 set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc1}] 5.000 set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc2}] 5.000 set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc3}] 5.000 set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc0}] 5.000 set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc1}] 5.000 set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc2}] 5.000 set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc3}] 5.000 set_min_delay -from [get_ports {tdo_unc0}] -to [get_ports {unc_jtag_tdo}] 5.000 set_min_delay -from [get_ports {tdo_unc1}] -to [get_ports {unc_jtag_tdo}] 5.000 set_min_delay -from [get_ports {tdo_unc2}] -to [get_ports {unc_jtag_tdo}] 5.000 set_min_delay -from [get_ports {tdo_unc3}] -to [get_ports {unc_jtag_tdo}] 5.000 Thanks, Neeraj
