14 years agoHow to reduce electromagnetic noises in EPM3000/7000
Hi everybody, Good evening. Is anyone know how to reduce the electromagnetic noises in EPM3000/7000. We faced with situation that newer CPLD families much noisy than the old ones. Ple...
14 years ago --- Quote Start --- The reason for that is most likely that the rise and fall times is much lower in newer families. --- Quote End --- Yes, that can be expected. But doesn't solve the problem. MAX3000 and 7000 don't have programmable IO strength, so the slow-slew-rate option is the only available means besides hardware modifications to handle the issue. Output series resistors, better supply bypassing, ferrite filters are possible means.
