11 years agoHow to rectify modelsim error "failed to open top_core.vo"?
I was trying to simulate PCI Express reference design as per instructions given in "ip compiler for pci express" (https://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0cb4qfjaaahuke...
11 years agoYes that is what I meant,
Now looks like you are trying to run a gate level simulation.. Can you double check if you have created the netlist successfully and the file is present at the location mentioned in .do file.
