14 years agoHow to receive slow bit stream data using GXB
Hi, Is there a way to use the GXB in Stratix IV to recover data/clock from a bit stream slower than 600Mbps? I know Xilinx transceivers can do this using oversampling. Thanks, Hua
14 years agoThe Stratix IV transceiver CDR is specified with a maximum run length of 200 UI. It's also clear that non-8B/10B-coded streams and DC coupling are supported. In so far, there should be a wide range of possible protocol implementations, including the said oversampling of lower bit rates than 600 MBPS.
The coding properties (run length, balancing) will still matter for the achievable performance.
