11 years agoHow to read data from a memory location where ADC conversion result is stored?
Hi, I am trying to use my ADC to sample an analog voltage. I used Qsys to design ADC modular core and was able to see the conversion result using ADC Toolkit. Now, I want to use this ADC conversi...
11 years agoHi Alex,
Thanks for your reply. I solved the problem. I was using static signals and now when i pulsed the start of packet and kept the command valid high all the time, it worked. The following part of the code is for Pulse Width Modulation (PWM) generator.What i intended to do earlier, is to read ADC data and use it to change the duty-cycle(or ON Time) of my pulse. Since, I was not ale to read ADC data, it kept it fixed earlier. The bottom code generates a counter for PWM. As, now I can read the ADC data, I am able to change this duty-cycle. Also, this code is not for university tutorial. It is for the industry. I am very new to VHDL coding and using FPGAs but certainly with your help I was able to correctly configure my ADC. Thanks again for your help! Regards, Misha Code: ..... process(shadowload,count) begin if (shadowload > count) then Su <= '0' ; Sb <= '1' after deadtime; else Sb <= '0'; Su <= '1' after deadtime; end if; end process; What relevance does the following code have to your ADC? Perhaps none, but that means there isn't any logic left! Code: process(clk_clk) begin if(rising_edge(clk_clk)) then if(count = PRD) then count <= to_unsigned(1,12); shadowload <= CMP; else count <= count + 1; end if; end if; end process; Code:
