11 years agoHow to read data from a memory location where ADC conversion result is stored?
Hi, I am trying to use my ADC to sample an analog voltage. I used Qsys to design ADC modular core and was able to see the conversion result using ADC Toolkit. Now, I want to use this ADC conversi...
11 years agoI feel there's quite a bit lacking in your code... You mention logic tap - can I assume you're trying to put this onto some hardware?
In your entity declaration - 'Su' & 'Sb', your hardware's only I/O, has nothing to do with the ADC. Is this intentional?entity ADC_PWM is
Port (
clk_clk : in STD_LOGIC;
Su : out STD_LOGIC;
Sb : out STD_LOGIC);
end ADC_PWM;
What are you hoping the following will do? It may simulate as you'd expect but it won't synthesize to anything you can put onto hardware. deadtime <= 500 ns;
process(shadowload,count)
begin
if (shadowload > count) then
Su <= '0' ;
Sb <= '1' after deadtime;
else
Sb <= '0';
Su <= '1' after deadtime;
end if;
end process;
What relevance does the following code have to your ADC? Perhaps none, but that means there isn't any logic left! process(clk_clk)
begin
if(rising_edge(clk_clk)) then
if(count = PRD) then
count <= to_unsigned(1,12);
shadowload <= CMP;
else
count <= count + 1;
end if;
end if;
end process;
signal ready,valid,sof,eof,empty,reset : std_logic := '0';
ADC1 : ADC port map(clk_clk,Y ,channel ,Y ,N ,ready,valid,sof,eof,empty,responsechannel, data, reset);
All those signals (ready,valid,sof etc.) are output signals from the ADC. The ADC drives these signals. You shouldn't be assigning them to '0'. None of your output signals connect to anything, except possibly your signal tap module. Signals that don't drive anything will result in chunks of logic being removed. If the ADC output signals don't actually drive anything what's to stop Quartus getting rid of it? (Yes, possibly signal tap.) All your ADC input signals are static. When I've previously played around with the ADC I found that didn't work - I had to control something. Looking back at my code the minimum I seemed to be able to get away with was pulsing 'command_valid', but I still had to pulse it. Your clock frequency - see table 5-1 on page 5-2 of the ADC document. Is you clock at an appropriate frequency? Is this a University tutorial? I feel you need a chat with your tutor... Cheers, Alex
