11 years agoHow to read data from a memory location where ADC conversion result is stored?
Hi, I am trying to use my ADC to sample an analog voltage. I used Qsys to design ADC modular core and was able to see the conversion result using ADC Toolkit. Now, I want to use this ADC conversi...
11 years agoHi Alex,
Thanks a lot for your reply. I followed what you suggested and qsys generated following example code for me. I included this code in my VHDL file.I have attached my VHDL code (at the bottom) where i want to read the data. The code is able to compile but i am not able to read the data. I used logic tap II analyzer to confirm that i am not reading ADC data. Kindly help. component ADC is port ( clk_clk : in std_logic := 'X'; -- clk modular_adc_0_command_valid : in std_logic := 'X'; -- valid modular_adc_0_command_channel : in std_logic_vector(4 downto 0) := (others => 'X'); -- channel modular_adc_0_command_startofpacket : in std_logic := 'X'; -- startofpacket modular_adc_0_command_endofpacket : in std_logic := 'X'; -- endofpacket modular_adc_0_command_ready : out std_logic; -- ready modular_adc_0_response_valid : out std_logic; -- valid modular_adc_0_response_startofpacket : out std_logic; -- startofpacket modular_adc_0_response_endofpacket : out std_logic; -- endofpacket modular_adc_0_response_empty : out std_logic; -- empty modular_adc_0_response_channel : out std_logic_vector(4 downto 0); -- channel modular_adc_0_response_data : out std_logic_vector(11 downto 0); -- data reset_reset_n : in std_logic := 'X' -- reset_n ); VHDL Code that I made: library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity ADC_PWM is Port ( clk_clk : in STD_LOGIC; Su : out STD_LOGIC; Sb : out STD_LOGIC); end ADC_PWM; architecture Behavioral of ADC_PWM is component ADC is port ( clk_clk : in std_logic := 'X'; -- clk modular_adc_0_command_valid : in std_logic := 'X'; -- valid modular_adc_0_command_channel : in std_logic_vector(4 downto 0) := (others => 'X'); -- channel modular_adc_0_command_startofpacket : in std_logic := 'X'; -- startofpacket modular_adc_0_command_endofpacket : in std_logic := 'X'; -- endofpacket modular_adc_0_command_ready : out std_logic; -- ready modular_adc_0_response_valid : out std_logic; -- valid modular_adc_0_response_startofpacket : out std_logic; -- startofpacket modular_adc_0_response_endofpacket : out std_logic; -- endofpacket modular_adc_0_response_empty : out std_logic; -- empty modular_adc_0_response_channel : out std_logic_vector(4 downto 0); -- channel modular_adc_0_response_data : out std_logic_vector(11 downto 0); -- data reset_reset_n : in std_logic := 'X' -- reset_n ); end component ADC; signal count,shadowload,CMP : unsigned (11 downto 0) := to_unsigned(0,12); signal deadtime : time := 500 ns; signal PRD : unsigned (11 downto 0) := to_unsigned(4000,12); signal Y : std_logic := '1'; signal N : std_logic := '0'; signal channel,responsechannel : std_logic_vector(4 downto 0) :=(others => '0'); signal data : std_logic_vector(11 downto 0) :=(others => '0'); signal ready,valid,sof,eof,empty,reset : std_logic := '0'; begin CMP <= to_unsigned(2000,12); deadtime <= 500 ns; ADC1 : ADC port map(clk_clk,Y ,channel ,Y ,N ,ready,valid,sof,eof,empty,responsechannel, data, reset); process(shadowload,count) begin if (shadowload > count) then Su <= '0' ; Sb <= '1' after deadtime; else Sb <= '0'; Su <= '1' after deadtime; end if; end process; process(clk_clk) begin if(rising_edge(clk_clk)) then if(count = PRD) then count <= to_unsigned(1,12); --shadowload <= unsigned(data); shadowload <= CMP; else count <= count + 1; end if; end if; end process; end Behavioral;
