16 years agohow to program the .elf file into the flash
use jtag to download the .elf into the ssram and run, use the command:
nios2-download -g *.elf , succeed. but if i want to download the .elf file into the flash and run , use this command , system generates message: downloaded 62kb in 1.4s(44.2kb/s) verifying 0c000000 (0%) verify failed between address 0xc000000 and 0x c00f54b leaving target processor paused. i have to use nios2 IDE. import the project, tools/flash programming/. this is too troublesome. who can tell me how to download the .elf file into the flash using command line method. thanks.2 Replies
You should confirm which component has the address 0xc000000
I don't have the DE2. But as far as I know, you need to use the "flash programmer" to download elf or sof files to flash via JTAG.
In your sopc system, a cfi flash controller is needed as well.
