16 years agohow to program the .elf file into the flash
use jtag to download the .elf into the ssram and run, use the command: nios2-download -g *.elf , succeed. but if i want to download the .elf file into the flash and run , use this command ...
16 years agoI don't have the DE2. But as far as I know, you need to use the "flash programmer" to download elf or sof files to flash via JTAG.
In your sopc system, a cfi flash controller is needed as well.
