16 years agohow to program the .elf file into the flash
use jtag to download the .elf into the ssram and run, use the command: nios2-download -g *.elf , succeed. but if i want to download the .elf file into the flash and run , use this command ...
16 years agoYou should confirm which component has the address 0xc000000
