How to program a FPGA cyclone IV EP4CE15F17I7?
I want to program a FPGA cyclone IV EP4CE15F17I7 but I do not know how to do it. I would like to know how I could do it also how to get a source file of one FPGA for programing another with the same file.
- AnandRaj_S_Intel
Hi Juan,
Yes, FPGA do not have a ROM memory internally but we can use external rom like EPCS device as flash.
Now you have to read the configuration image (.pof) from external flash.
To get source files from flash, You have you use the flash loader to establish a bridge between flash and cable. Refer below link
https://www.intel.com/content/www/us/en/programmable/documentation/mwh1410805299012.html
After loading flash loader (sof) in FPGA auto-detect and use the Examine feature in the Quartus® II Programmer to read back the .pof. You can then save this file and use it to program other EPCS devices
Anand
- jalon5
I am not using any Development kit, I have two FPGA EP4CE15F17I7 in other board and I want to know if I can program it because I read that this FPGA do not have a ROM memory internally and I do not know how to program if only have a RAM memory. Could you tell me if the information I read is correct? or where can I get more information about it?
I am checking your information but I am a new to program FPGAs.
jalon5
- AnandRaj_S_Intel
Are you using a Development kit?
- Check which configuration scheme is used on your board.
- Refer below user-guide for programming steps session 4.1.
Anand
