16 years agoHow to process this warning?!
Hi Dears:
I got below warning after compiling: "Warning: Found 43 output pins without output pin load capacitance assignment" My question is that how to assign this assignment? What function of this assignment? And I can see some informations following this warning is below: " Info: Pin "FPGA_OE" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis" Is it mean that the QII would assign with a default value and we can ignore this warning?2 Replies
Hi pletz:
Noted it. Thanks! - Altera_Forum
--- Quote Start --- Hi Dears: I got below warning after compiling: "Warning: Found 43 output pins without output pin load capacitance assignment" My question is that how to assign this assignment? What function of this assignment? And I can see some informations following this warning is below: " Info: Pin "FPGA_OE" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis" Is it mean that the QII would assign with a default value and we can ignore this warning? --- Quote End --- Hi Jerry, the assignment would enhance the precision of the timing analysis. As long as you are not working on a highspeed interface like DDR2/DDR3 you can ignore the warning at the beginning. If you have this information ( maybe from your PCB tool) you can set this assignment in the Assignment Editor ( Ouput pin load). The Quartus deflaut value is 0 pF. Kind regards GPK
