12 years agoHow to measure distance between two data
really i have a problem for measure the distance between these data as the following.could i can make it in vhdl from enter this data to vhdl to measure distance between them. d(s1,s2)=(1+1+0+1+1)...
12 years ago --- Quote Start --- d(s1,s2) is the distance between the position of each element in s1 and the position of the same element in s2 which is 1+1+0+1+1=4 then divided by (n^2-1)/2 where n is the number of elements in table sorry for not clear at first. i want to make a vhdl code for that so i need help --- Quote End --- So in the given case you have the given distances as 1+1+0+1+1 (n = 5) so distance = 1+1+0+1+1 = 4 then normalised to 5^2-1/2 i.e. /12 =.333 is n constant 5 always. How do you get the positions of 1,1,0,1,1? are these five inputs? Once you are clear about the requirement then you can go for coding.
