18 years agoHow to make the output of PLLs in differrent FPGA devices synchronous with each oth
PLLs in differrent devices have the same settings and the same clock source(as attached plot). I need the PLL output of clk1 and clk2 to be synchronous with each other. How to do it? Could you help ...
18 years agoHi,
Fore me it seems like Try to connect the PLLs with a dedicated line (see the board layout manual) for Ex: CoreClk (10MHz) : in std_logic; oClk <= CoreClk; Take an extra port oClk : out std_logic; (in Device 1) and iClk : in std_logic ; (in Device 2) and also try to adjust the different phases which can be statistically set in MegaCore Wizard.
