14 years agoHow to make bidirectional bus in SystemVerilog
I have a bidirectional 8 bit bus for communicating between my CPLD and my main CPU. At the top level module I declared this like this (left out details of other IO stuff):
module top ( inout [7:0] gpbus, input bit rd, input bit wr ); When I drive the gpbus from my test bench it works fine. When I set the gpbus to 8'bZ it does tri-state it. However, when I drive it from inside my module nothing changes at the test bench. It stays tri-stated. How do I correctly create and connect such a bus and simulate it? I've tried using the alias statement but no matter what I do that creates an error "near text 'alias' expecting endmodule".11 Replies
Most likely a connection error, but you did not show enough code that might give a hint at what is wrong. How are you driving the bus in your testbench and CPLD? You need to be using a continuous assignment in both places. Either
assign gpbus = wr ? data : 8'z; or assign gpbus = data; And you procedurally assign data to 8'bz when that side is not driving.
