20 years agoHow to make applications run on nios2linux
Hi , How to make applications run on nios2linux by comman mount or ftpd. because the kernel is romfs, I can't mount linux host and windows xp. I can't send files to filesystem by ftpd ei...
20 years ago --- Quote Start --- originally posted by zzh@Mar 8 2006, 08:24 AM hi ,
how to make applications run on nios2linux by comman mount or ftpd.
because the kernel is romfs, i can't mount linux host and windows xp. i can't send files to filesystem by ftpd either.
does somebody want to give a hand?
my qq is 332418170. waiting for you!!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13217)
--- quote end ---
--- Quote End --- I've never used ftpd ever , but I use NFS very efficiently. On the DE2 board , I use usb-blaster to download Image file under windows ,and at the same time another computer to builde and compile kernel or my own app under Linux throuht nfs (ethnet Interface),I use uclinux. It's very simple ,following hippo's particle step by step ,.you may try. And make sure that your firewall is disabled when you mount or ftpd.
