14 years agohow to know the result of serial loopback test by using PRBS?
Hi All, I am using Stratix IV GT device. I have done some configuration to connect my switch to PMA of the GT device. However, firstly, I want to check if my configuration is correct or not, so ...
14 years agoThe Transceiver Toolkit provides a good interface for the kind of testing you're looking for. It lets you put in different PRBS patterns and check bit error rates. It also lets you change transceiver settings.
Download the appropriate example project and modify for your setup. http://www.altera.com/support/examples/on-chip-debugging/on-chip-debugging.html
