14 years agoHOW TO INTERFACE BETWEEN ETHERNET(CYCLONE III) AND PCs(Labtop)
Hi everybody!!! I'm studying with a topics "Interface between Ethernet of Cyclone III and computer(PC or labtop)" It's means that I must "ping IP and Relay from Cyclone's Ethernet". I don...
14 years agoDear Daixiwen! Under the derection of you. I have done here. I do like this is true?
I defined the IP as below. :) * If DHCP will not be used, select valid static IP addresses here, for example: * IP: 192.168.1.234 * Gateway: 192.168.1.1 * Subnet Mask: 255.255.255.0 # define IPADDR0 192 # define IPADDR1 168 # define IPADDR2 1 # define IPADDR3 234 # define GWADDR0 192 # define GWADDR1 168 # define GWADDR2 1 # define GWADDR3 1 # define MSKADDR0 255 # define MSKADDR1 255 # define MSKADDR2 255 # define MSKADDR3 0
