14 years agoHOW TO INTERFACE BETWEEN ETHERNET(CYCLONE III) AND PCs(Labtop)
Hi everybody!!! I'm studying with a topics "Interface between Ethernet of Cyclone III and computer(PC or labtop)" It's means that I must "ping IP and Relay from Cyclone's Ethernet". I don...
14 years agoI'm sorry I don't understand what you are saying... further up you said you were using dhcp, but new you are back at defining the ip yourself...
The IP 192.168.1.234 is inside a comment, it will never be read or used by the compiler. You must define the IPADDR0-3 constants to force an IP address. And remember to turn off the DHCP_CLIENT define too. What does it say in the nios terminal when you run the application? It will tell you what IP address it is using (as I've already said).
